Why didn't Philco make a multiband portable?
Reflecting the Cold-War Era's "doom & gloom" maybe?
Chuck
Re: Why didn't Philco make a multiband portable? - by Chuck Schwark - 07-21-2011, 01:07 PM
There are currently 8518 online users. [Complete List]
» 1 Member(s) | 8517 Guest(s)
