Philco 91X for $40.00
Hi Dan, and welcome aboard! Icon_biggrin
I've always admired the looks of the 91X (although I've never owned one), and with nine tubes it should be a great performer. I have the 91B cathedral, and a few months ago added a 91D console with doors to my collection.
I do have a 15X (eleven tubes), and will be acquiring an early version 19X in a month or so.
Philco 91X for $40.00 - by Dan Walker - 07-21-2011, 09:59 PM
Re: Philco 91X for $40.00 - by Ron Ramirez - 07-21-2011, 10:23 PM
Re: Philco 91X for $40.00 - by Michael Dennis - 07-21-2011, 11:15 PM
Re: Philco 91X for $40.00 - by Dan Walker - 07-21-2011, 11:23 PM
Re: Philco 91X for $40.00 - by Michael Dennis - 07-22-2011, 06:36 AM
Re: Philco 91X for $40.00 - by Dan Walker - 07-22-2011, 10:35 AM
Re: Philco 91X for $40.00 - by Michael Dennis - 07-22-2011, 10:40 AM
Re: Philco 91X for $40.00 - by Ron Ramirez - 07-22-2011, 04:51 PM
Re: Philco 91X for $40.00 - by Michael Dennis - 07-22-2011, 05:31 PM
There are currently 10404 online users. [Complete List]
» 2 Member(s) | 10402 Guest(s)
