Model 50A rebuild
I have worked over the variable cap. It does seem to have the ohms cited above.
Still no sound.
Who would be able to supply me with the voltages going into and out of the tubes (the filaments voltage seem to all be stable as does the output of transformer).
There seems to be very little power going to the speaker leads.
Thank you
Model 50A rebuild - by Mtmattking - 04-08-2024, 07:19 PM
RE: Model 50A rebuild - by GarySP - 04-08-2024, 08:43 PM
RE: Model 50A rebuild - by morzh - 04-08-2024, 09:30 PM
RE: Model 50A rebuild - by Mtmattking - 04-08-2024, 09:35 PM
RE: Model 50A rebuild - by Mtmattking - 04-08-2024, 09:37 PM
RE: Model 50A rebuild - by klondike98 - 04-08-2024, 09:51 PM
RE: Model 50A rebuild - by Mtmattking - 04-08-2024, 09:57 PM
RE: Model 50A rebuild - by klondike98 - 04-09-2024, 03:20 AM
RE: Model 50A rebuild - by Mtmattking - 04-09-2024, 10:56 PM
RE: Model 50A rebuild - by morzh - 04-11-2024, 08:01 AM
RE: Model 50A rebuild - by Mtmattking - 06-29-2024, 09:58 PM
RE: Model 50A rebuild - by morzh - 06-30-2024, 11:07 AM
RE: Model 50A rebuild - by Mtmattking - 06-30-2024, 12:41 PM
RE: Model 50A rebuild - by morzh - 06-30-2024, 01:16 PM
RE: Model 50A rebuild - by GarySP - 06-30-2024, 04:25 PM
RE: Model 50A rebuild - by Mtmattking - 07-06-2024, 08:26 PM
RE: Model 50A rebuild - by morzh - 07-06-2024, 10:20 PM
RE: Model 50A rebuild - by Mtmattking - 07-07-2024, 01:00 AM
RE: Model 50A rebuild - by RodB - 07-07-2024, 09:24 AM
RE: Model 50A rebuild - by Chas - 07-07-2024, 09:50 AM
RE: Model 50A rebuild - by Paul Philco322 - 07-07-2024, 01:19 PM
RE: Model 50A rebuild - by GarySP - 07-07-2024, 03:19 PM
RE: Model 50A rebuild - by morzh - 07-07-2024, 07:33 PM
RE: Model 50A rebuild - by Mtmattking - 07-15-2024, 01:02 PM
RE: Model 50A rebuild - by Mtmattking - 07-20-2024, 10:28 PM
RE: Model 50A rebuild - by Radioroslyn - 07-22-2024, 09:29 AM
RE: Model 50A rebuild - by Mtmattking - 07-22-2024, 07:10 PM
RE: Model 50A rebuild - by Radioroslyn - 07-23-2024, 07:58 AM
RE: Model 50 Capacitor values - by Mtmattking - 04-08-2024, 10:39 PM
