model 19 code 126
Unless the shadowmeter was replaced with a late 1936 type shadowmeter (with a thumbscrew in back) which requires no parallel resistor, then I would say that your resistor is just missing.
model 19 code 126 - by vinzer - 07-22-2011, 04:24 PM
Re: model 19 code 126 - by Ron Ramirez - 07-22-2011, 04:42 PM
Re: model 19 code 126 - by vinzer - 07-22-2011, 05:19 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6223 online users. [Complete List]
» 1 Member(s) | 6222 Guest(s)
