PT-6 antenna
Try feeding a modulated IF signal to the antenna. If you get a tone at the speaker then check to see if the local oscillator is running.
PT-6 antenna - by bridkarl - 08-03-2024, 01:35 PM
RE: PT-6 antenna - by RodB - 08-03-2024, 01:58 PM
RE: PT-6 antenna - by bridkarl - 08-04-2024, 09:46 AM
462ron - by 462ron - 08-05-2024, 08:04 AM
RE: PT-6 antenna - by bridkarl - 08-06-2024, 08:53 PM
RE: PT-6 antenna - by MrFixr55 - 08-08-2024, 09:37 PM
