Model 41-295 rectifier tube 5Z3 vs 80
If the 5Z3 and filters look original, I'd say stay with those components and values.The discrepancy may be the result of a production line change. The other possibility is difference between console and table versions of the chassis.
Model 41-295 rectifier tube 5Z3 vs 80 - by FredM - 08-13-2024, 05:30 AM
RE: Model 41-295 rectifier tube 5Z3 vs 80 - by Brad Winder - 08-13-2024, 07:47 AM
