Model 41-295 rectifier tube 5Z3 vs 80
Don't tell anybody the filament on the 5Z3 (like the 5U4) is 3a not 5a. But you can get 250ma of dc current output vs 125ma of the 80 (5Y3). I would go w/the 80 tube also.
Model 41-295 rectifier tube 5Z3 vs 80 - by FredM - 08-13-2024, 05:30 AM
RE: Model 41-295 rectifier tube 5Z3 vs 80 - by Radioroslyn - 08-14-2024, 09:09 PM
