Philco 41-226
Found this radio at the local flea market a couple weeks ago, luckily it was still there this afternoon and marked down on the price.[attachment=0]
Has some blemishes and over the past couple weeks someone poked and cracked the plastic dial cover which was perfect the first time I saw the radio. Something about the looks of this radio caught my eye.
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Philco 41-226 - by Jayce - 07-23-2011, 06:23 PM
RE: Philco 41-226 - by Ron Ramirez - 05-04-2012, 11:16 AM
RE: Philco 41-226 - by imacdaddy757 - 05-04-2012, 07:25 PM
RE: Philco 41-226 - by Ron Ramirez - 05-05-2012, 07:25 AM
Re: Philco 41-226 - by Ron Ramirez - 07-23-2011, 06:43 PM
RE: Philco 41-226 - by imacdaddy757 - 05-04-2012, 07:27 AM
RE: Philco 41-226 - by Chuck Schwark - 05-04-2012, 10:06 AM
Re: Philco 41-226 - by Jayce - 07-24-2011, 04:13 PM
Re: Philco 41-226 - by Arran - 07-25-2011, 06:01 AM
Philco 91 Tuning Condenser
