Tinkering on the Westinghouse H-777N7
12AT7 vs 12DT8 some books show they are a sub for each other WRONG!  Pin nine on the 12DT8 goes to ground a internal shield. Pin nine on the 12AT7 is a center tap for the heater. I learned the hard way. David
Tinkering on the Westinghouse H-777N7 - by Jayce - 08-18-2024, 01:41 PM
RE: Tinkering on the Westinghouse H-777N7 - by David - 08-18-2024, 05:47 PM
