Philco 46-480 Power Supply
Mr. Fixr, you are right. I looked back at my notes, and it turns out that I did not use type Y caps on my model 49-906's filter caps. For some odd reason I was thinking I had done so.
    Morzh, thank you for the detailed insight into the different types of capacitors. I appreciate that! It's funny--I am a transmission station engineer, and deal with carrier signals and interference on lines all the time. However, the means are a bit different here when we're only working with 120V instead of hundreds of thousands of volts. The means of fault mitigation are different, too! I am realizing I have much to learn.
    I will use type Y safety caps for the two capacitors on the primary side of the transformer (C100A and C100B), and regular electrolytic capacitors for the filter caps. Thank you all!
Joseph
Philco 46-480
Philco 49-906
Philco 46-480 Power Supply - by jrblasde - 08-18-2024, 09:20 AM
RE: Philco 46-480 Power Supply - by RodB - 08-18-2024, 10:26 AM
RE: Philco 46-480 Power Supply - by MrFixr55 - 08-18-2024, 10:34 AM
RE: Philco 46-480 Power Supply - by jrblasde - 08-18-2024, 10:36 AM
RE: Philco 46-480 Power Supply - by jrblasde - 08-18-2024, 11:01 AM
RE: Philco 46-480 Power Supply - by morzh - 08-18-2024, 11:30 AM
RE: Philco 46-480 Power Supply - by jrblasde - 08-18-2024, 07:31 PM
RE: Philco 46-480 Power Supply - by morzh - 08-18-2024, 09:16 PM
RE: Philco 46-480 Power Supply - by MrFixr55 - 08-19-2024, 08:52 AM
RE: Philco 46-480 Power Supply - by morzh - 08-19-2024, 09:47 AM
462ron - by 462ron - 08-20-2024, 07:56 AM
RE: Philco 46-480 Power Supply - by jrblasde - 08-20-2024, 06:10 PM
RE: Philco 46-480 Power Supply - by morzh - 08-20-2024, 08:06 PM
RE: Philco 46-480 Power Supply - by jrblasde - 12-26-2024, 03:47 PM
RE: Philco 46-480 Power Supply - by tbone - 12-27-2024, 08:37 AM
RE: Philco 46-480 Power Supply - by jrblasde - 12-27-2024, 08:54 AM
RE: Philco 46-480 Power Supply - by morzh - 12-27-2024, 10:38 AM
RE: Philco 46-480 Power Supply - by jrblasde - 12-27-2024, 10:54 AM
RE: Philco 46-480 Power Supply - by morzh - 12-27-2024, 10:58 AM
RE: Philco 46-480 Power Supply - by jrblasde - 12-27-2024, 11:07 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 3668 online users. [Complete List]
» 1 Member(s) | 3667 Guest(s)
