Philco Model 512 Mandarin Red - LOC Terminal
Well it does a couple of things. It will shock you if you touch your fingers between LOC & GND, it acts as a line filter, and back in the 1920's it might have been used as an antenna connection. Wouldn't try it now too much interference. The best this to do is connect it to GND on the chassis and connect that to earth gnd (not thru the house wiring if you can help it)
de N3GTE
RE: Philco Model 512 Mandarin Red - LOC Terminal - by Radioroslyn - 08-19-2024, 08:10 AM
Eico 232 VTVM Schematic
There are currently 3184 online users. [Complete List]
» 2 Member(s) | 3182 Guest(s)
