PT-6 antenna connections
Notice in the schematic the notch at the bottom of the antenna coil is between pins 3 & 4.
Yes, pin 6 of the 7C6 is the AVC connection I referred to above. It should connect to pin 4 of the antenna transformer.
PT-6 antenna connections - by bridkarl - 08-24-2024, 01:30 PM
RE: PT-6 antenna connections - by RodB - 08-24-2024, 07:34 PM
bridkarl - by bridkarl - 08-24-2024, 08:23 PM
RE: PT-6 antenna connections - by RodB - 08-24-2024, 08:34 PM
RE: PT-6 antenna connections - by bridkarl - 08-24-2024, 09:13 PM
RE: PT-6 antenna connections - by MrFixr55 - 08-25-2024, 08:30 AM
RE: PT-6 antenna connections - by bridkarl - 08-25-2024, 01:37 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8776 online users. [Complete List]
» 3 Member(s) | 8773 Guest(s)
