PT-6 antenna connections
Thanks. I never realized that was a notch noted in the schematic as described. I’ll recheck my wiring.
PT-6 antenna connections - by bridkarl - 08-24-2024, 01:30 PM
RE: PT-6 antenna connections - by RodB - 08-24-2024, 07:34 PM
bridkarl - by bridkarl - 08-24-2024, 08:23 PM
RE: PT-6 antenna connections - by RodB - 08-24-2024, 08:34 PM
RE: PT-6 antenna connections - by bridkarl - 08-24-2024, 09:13 PM
RE: PT-6 antenna connections - by MrFixr55 - 08-25-2024, 08:30 AM
RE: PT-6 antenna connections - by bridkarl - 08-25-2024, 01:37 PM
