E H Scott Allwave 15
I've just taken one of these sets in for restoration. What a behemoth! After re-stuffing all the wee capacitor cans & replacing all out-of-spec resistors, I have the powered it up. The audio & IF sections are all fine but I cannot get the local oscillator to cooperate. Any suggestions? Also the mixer tube in this particular set is a 58, not a 2A7 as the two circuits I have found, show. The circuit of the audio amp is also a bit different. The detector is the full-wave type using both diodes of the 55 valve and the Radio Museum info suggests that this was employed in a later version of the circuit but the 58 mixer would suggest otherwise. I therefore assume that there are other circuits somewhere out there. All very interesting. Michael, does your manual contain a circuit that you could copy for me please?
E H Scott Allwave 15 - by Michael Dennis - 03-19-2012, 11:50 AM
RE: E H Scott Allwave 15 - by codefox1 - 03-19-2012, 03:10 PM
RE: E H Scott Allwave 15 - by TA Forbes - 03-19-2012, 03:34 PM
RE: E H Scott Allwave 15 - by Michael Dennis - 03-19-2012, 03:42 PM
RE: E H Scott Allwave 15 - by Michael Dennis - 03-19-2012, 03:46 PM
RE: E H Scott Allwave 15 - by Michael Dennis - 03-22-2012, 10:20 PM
RE: E H Scott Allwave 15 - by Philconut - 08-25-2024, 05:34 PM
RE: E H Scott Allwave 15 - by GarySP - 08-25-2024, 06:24 PM
