38-62 new volume problem
Ditto. I have a set that I Successfully repaired several years ago and it developed the same symptoms. I spent a lot of time messing with it and it turned out the speaker was at fault.
38-62 new volume problem - by Chicago Jimmy - 07-25-2011, 05:34 PM
Re: 38-62 new volume problem - by codefox1 - 07-25-2011, 06:17 PM
Re: 38-62 new volume problem - by exray - 07-25-2011, 06:50 PM
Re: 38-62 new volume problem - by Chicago Jimmy - 07-25-2011, 07:50 PM
Re: 38-62 new volume problem - by Chicago Jimmy - 07-26-2011, 08:26 PM
Re: 38-62 new volume problem - by codefox1 - 07-27-2011, 05:43 AM
Re: 38-62 new volume problem - by Chicago Jimmy - 07-27-2011, 05:18 PM
Re: 38-62 new volume problem - by codefox1 - 07-27-2011, 06:21 PM
Re: 38-62 new volume problem - by Chicago Jimmy - 07-27-2011, 07:43 PM
Re: 38-62 new volume problem - by Chicago Jimmy - 07-30-2011, 01:01 PM
Re: 38-62 new volume problem - by Chicago Jimmy - 08-04-2011, 06:38 PM
Re: 38-62 new volume problem - by 7estatdef - 08-04-2011, 08:37 PM
Re: 38-62 new volume problem - by Chicago Jimmy - 08-07-2011, 03:57 PM
Re: 38-62 new volume problem - by 7estatdef - 08-07-2011, 05:09 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6226 online users. [Complete List]
» 1 Member(s) | 6225 Guest(s)
