Philco 39-116 radio and remote
#38
Hi Rich,
From my experience, unfortunately it is not uncommon to find the power transformer in the 39-116 to be overheated and possibly shorted. I have seen many examples that have either had their transformer replaced or are found with a damaged transformer. My thoughts on these are:
-For the physical size of the transformer and the demand this large chassis is putting on the transformer, they build up a lot of heat.
-The rubber wiring that was used by Philco and other manufacturers at that time deteriorated and shorted. The rubber coating turned rock hard, and the excessive heat accelerated the problem.
I am currently working on a 39-3116X which is the Canadian version of the 39-116X. Philco in Canada didn't use rubber covered wiring (Yay!!!) but on the 39-3116 chassis, they did source a number of specialized parts from the U.S. parent company, two of them being the power transformer and the selector lamp wiring harness. When I found this particular set, it had a replacement transformer haphazardly "installed" and I could tell from the burn marks under the chassis that a catastrophic end had come to the original transformer.
I was able to source a much beefier transformer to put in it...its from a late 40's Philco television! It has all the correct voltage windings, and it will juuuuuust fit into the chassis.
Philco 39-116 radio and remote - by RichG - 07-17-2024, 02:14 PM
RE: Philco 39-116 radio and remote - by GarySP - 07-17-2024, 04:50 PM
RE: Philco 39-116 radio and remote - by RichG - 07-17-2024, 09:36 PM
RE: Philco 39-116 radio and remote - by RichG - 07-17-2024, 09:47 PM
RE: Philco 39-116 radio and remote - by RichG - 07-18-2024, 08:00 PM
RE: Philco 39-116 radio and remote - by RichG - 07-21-2024, 05:04 PM
RE: Philco 39-116 radio and remote - by RichG - 08-10-2024, 02:30 PM
RE: Philco 39-116 radio and remote - by jrblasde - 08-10-2024, 07:03 PM
RE: Philco 39-116 radio and remote - by RichG - 08-17-2024, 08:14 PM
RE: Philco 39-116 radio and remote - by RodB - 08-17-2024, 08:50 PM
RE: Philco 39-116 radio and remote - by RichG - 08-18-2024, 01:27 AM
RE: Philco 39-116 radio and remote - by MrFixr55 - 08-18-2024, 10:04 AM
RE: Philco 39-116 radio and remote - by RodB - 08-18-2024, 10:08 AM
RE: Philco 39-116 radio and remote - by morzh - 08-18-2024, 11:10 AM
RE: Philco 39-116 radio and remote - by jrblasde - 08-18-2024, 01:35 PM
RE: Philco 39-116 radio and remote - by RichG - 08-27-2024, 07:41 PM
RE: Philco 39-116 radio and remote - by RodB - 08-27-2024, 08:41 PM
RE: Philco 39-116 radio and remote - by RichG - 08-28-2024, 01:22 AM
RE: Philco 39-116 radio and remote - by GarySP - 08-28-2024, 07:59 PM
RE: Philco 39-116 radio and remote - by RichG - 08-28-2024, 09:18 PM
RE: Philco 39-116 radio and remote - by Chas - 08-28-2024, 11:29 PM
RE: Philco 39-116 radio and remote - by RichG - 08-29-2024, 01:37 AM
462ron - by 462ron - 08-29-2024, 07:50 AM
RE: Philco 39-116 radio and remote - by RodB - 08-29-2024, 09:08 AM
RE: Philco 39-116 radio and remote - by RichG - 08-31-2024, 01:27 PM
462ron - by 462ron - 09-01-2024, 08:36 AM
RE: Philco 39-116 radio and remote - by RichG - 09-01-2024, 01:19 PM
462ron - by 462ron - 09-02-2024, 07:52 AM
RE: Philco 39-116 radio and remote - by RichG - 09-04-2024, 01:16 PM
RE: Philco 39-116 radio and remote - by RichG - 09-04-2024, 01:33 PM
RE: Philco 39-116 radio and remote - by Chas - 09-04-2024, 05:02 PM
RE: Philco 39-116 radio and remote - by RichG - 09-04-2024, 08:41 PM
RE: Philco 39-116 radio and remote - by GarySP - 09-04-2024, 09:15 PM
RE: Philco 39-116 radio and remote - by Chas - 09-04-2024, 10:34 PM
RE: Philco 39-116 radio and remote - by RichG - 09-15-2024, 06:31 PM
RE: Philco 39-116 radio and remote - by RichG - 09-15-2024, 09:15 PM
RE: Philco 39-116 radio and remote - by Brad Winder - 09-19-2024, 10:25 AM
RE: Philco 39-116 radio and remote - by RichG - 09-19-2024, 04:01 PM
RE: Philco 39-116 radio and remote - by RichG - 09-20-2024, 05:32 PM
RE: Philco 39-116 radio and remote - by RichG - 11-04-2024, 08:00 PM
RE: Philco 39-116 radio and remote - by morzh - 11-04-2024, 10:25 PM
RE: Philco 39-116 radio and remote - by rfeenstra - 11-05-2024, 01:02 AM
RE: Philco 39-116 radio and remote - by RichG - 11-06-2024, 03:38 PM
RE: Philco 39-116 radio and remote - by Arran - 11-13-2024, 08:37 PM
RE: Philco 39-116 radio and remote - by RichG - 11-15-2024, 05:21 PM
