replace bakelite condensers on 84b ?
Welcome Seguida...Yes,you can rebuild them...read up on them here on.Take your time,and you can use the orange dips.
http://www.philcorepairbench.com/bblokcap.htm
http://www.philcorepairbench.com/capbuild.htm
replace bakelite condensers on 84b ? - by seguida - 07-26-2011, 11:33 AM
Re: replace bakelite condensers on 84b ? - by Chicago Jimmy - 07-26-2011, 05:22 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6078 online users. [Complete List]
» 1 Member(s) | 6077 Guest(s)
