Philco 48-200 alignment questions
Use an isolation transformer and you could just connect the output of the generator to the ant connection. Set the dial for 550kc. There's enough signal leakage thru the 7A8 that you'll hear it fine.
As for the adjustments on the tuning cap one is going to set the placement of the stations @ the top end of the dial and the other sets the sensitivity. Both of these you could use local stations the adjust. Or you could use a gimmick cap.
Philco 48-200 alignment questions - by transitony - 09-24-2024, 06:45 PM
RE: Philco 48-200 alignment questions - by Radioroslyn - 09-24-2024, 08:20 PM
RE: Philco 48-200 alignment questions - by RodB - 09-24-2024, 08:39 PM
RE: Philco 48-200 alignment questions - by RodB - 09-24-2024, 08:46 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 3467 online users. [Complete List]
» 1 Member(s) | 3466 Guest(s)
