1929 highboy cabinet door pulls
I recently acquired a model 87 with one broken (and loose) door pull. I was able to unscrew it. The door has a hold bored in the front not all the way through that holds a metal disk with a hole in the middle that traps a screw in the center of the hole. The pull threads onto the end of the screw and tightens down on the front of the door. It is a standard right hand thread. I don't have the screw in-hand at the moment, so I can't tell you the exact size and thread (or whether it is a modern size and thread). My disk has come loose and no long properly traps the screw, so I am planning to pull it out and set it back in, probably using hide-glue to hold both the disk and screw.
If anyone has a spare set of door pulls for this radio, I would love to hear from you. I will be searching...
1929 highboy cabinet door pulls - by Jim Skelly - 01-26-2010, 11:19 PM
RE: 1929 highboy cabinet door pulls - by visierl - 09-29-2024, 09:14 PM
RE: 1929 highboy cabinet door pulls - by visierl - 09-30-2024, 08:50 AM
RE: 1929 highboy cabinet door pulls - by RodB - 09-30-2024, 09:51 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 10452 online users. [Complete List]
» 1 Member(s) | 10451 Guest(s)
