Correct model 84 Ac plug an cord type
Hello Bruce,
I mostly use brown far as my cloth powercords go !
Here is the plug that I have used bakelite Acorn style
Correct model 84 Ac plug an cord type - by Bruce - 10-01-2024, 05:13 PM
RE: Correct model 84 Ac plug an cord type - by radiorich - 10-01-2024, 09:05 PM
