Hello and a 37-675
Hi Greg
At 115 volts, 155 watts translates to roughly 1.35 amp. So you should be fine with 2A fuses.
The dual 0.15 uF bakelite block (127) is connected so that both 0.15 uF caps are in parallel, resulting in a total capacity of 0.3 uF. This capacitor is intended to tune the filter choke (126) to help eliminate 60 cycle hum. But since you will replace (or have replaced) electrolytics (125) and (128) with 10 uF caps (larger than the original 8 uF), you don't need to reconnect (127) unless you want to.
Hello and a 37-675 - by gvel - 03-08-2011, 08:48 PM
RE: Hello and a 37-675 - by gvel - 04-18-2012, 06:03 PM
Re: Hello and a 37-675 - by TA Forbes - 03-08-2011, 10:35 PM
Re: Hello and a 37-675 - by TA Forbes - 03-08-2011, 10:37 PM
Re: Hello and a 37-675 - by 7estatdef - 03-08-2011, 11:10 PM
Re: Hello and a 37-675 - by TA Forbes - 03-09-2011, 08:58 AM
Re: Hello and a 37-675 - by Sean - 03-09-2011, 10:08 AM
Re: Hello and a 37-675 - by 7estatdef - 03-09-2011, 05:33 PM
Re: Hello and a 37-675 - by planigan - 03-09-2011, 11:53 PM
Re: Hello and a 37-675 - by Ron Ramirez - 03-10-2011, 09:55 AM
Re: Hello and a 37-675 - by planigan - 03-10-2011, 10:31 AM
Re: Hello and a 37-675 - by gvel - 03-10-2011, 08:18 PM
Re: Hello and a 37-675 - by planigan - 03-11-2011, 01:53 AM
Re: Hello and a 37-675 - by gvel - 03-11-2011, 07:53 AM
Re: Hello and a 37-675 - by gvel - 03-13-2011, 05:33 PM
Re: Hello and a 37-675 - by gvel - 03-27-2011, 12:56 PM
Re: Hello and a 37-675 - by planigan - 03-27-2011, 02:46 PM
Re: Hello and a 37-675 - by 7estatdef - 03-27-2011, 09:55 PM
Re: Hello and a 37-675 - by Jim Berg - 04-13-2011, 11:48 PM
Re: Hello and a 37-675 - by gvel - 07-24-2011, 12:30 PM
Re: Hello and a 37-675 - by gvel - 07-27-2011, 07:38 PM
Re: Hello and a 37-675 - by Ron Ramirez - 07-27-2011, 08:19 PM
Re: Hello and a 37-675 - by gvel - 07-27-2011, 09:34 PM
Re: Hello and a 37-675 - by gvel - 07-28-2011, 10:24 PM
Re: Hello and a 37-675 - by gvel - 08-07-2011, 09:20 PM
Re: Hello and a 37-675 - by codefox1 - 08-08-2011, 12:21 AM
Re: Hello and a 37-675 - by Ron Ramirez - 08-08-2011, 07:18 AM
Re: Hello and a 37-675 - by gvel - 08-09-2011, 07:32 PM
Re: Hello and a 37-675 - by codefox1 - 08-09-2011, 10:19 PM
Re: Hello and a 37-675 - by gvel - 08-10-2011, 09:43 AM
Re: Hello and a 37-675 - by gvel - 08-20-2011, 06:45 PM
Re: Hello and a 37-675 - by gvel - 08-21-2011, 07:15 PM
Re: Hello and a 37-675 - by gvel - 08-27-2011, 09:37 PM
Re: Hello and a 37-675 - by gvel - 08-28-2011, 04:21 PM
Re: Hello and a 37-675 - by Ron Ramirez - 08-28-2011, 05:18 PM
Re: Hello and a 37-675 - by gvel - 08-28-2011, 07:39 PM
Re: Hello and a 37-675 - by gvel - 09-07-2011, 10:47 AM
Re: Hello and a 37-675 - by gvel - 09-08-2011, 04:01 PM
Re: Hello and a 37-675 - by Ron Ramirez - 09-08-2011, 07:24 PM
Re: Hello and a 37-675 - by gvel - 09-09-2011, 11:12 AM
Re: Hello and a 37-675 - by gvel - 09-09-2011, 05:50 PM
Re: Hello and a 37-675 - by Ron Ramirez - 09-09-2011, 08:03 PM
Users browsing this thread: 13 Guest(s)
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6887 online users. [Complete List]
» 1 Member(s) | 6886 Guest(s)
