41-250 console vs table model
Can someone please tell me if there is any difference in the chassis for a table model versus a console. In other words are they wired up the same? I only physical difference I see is 6" vs. 12" speakers. My schematic dosen't show any difference that I can see. Thanks for any help, Bill
41-250 console vs table model - by williec - 07-27-2011, 08:40 PM
Re: 41-250 console vs table model - by williec - 07-27-2011, 09:55 PM
Re: 41-250 console vs table model - by Arran - 07-29-2011, 05:12 PM
There are currently 10046 online users. [Complete List]
» 2 Member(s) | 10044 Guest(s)
