Threads: 11
City: Greenlawn
State, Province, Country: NY
Interesting set on several levels. Interesting that it uses a bias cell for the 6Q7 grid. Wonder why they did not use the field coil as part of the power supply filter, putting it across the B supply instead? Did they get better flux that way? First time I saw an AC-DC radio use 2 chokes.
Good luck with the restoration, the radio is a looker.
RE: Restoring Philco 37-604C - by MrFixr55 - 10-09-2024, 10:30 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
