Threads: 562
Yeah yeah yeah. Eventually it will take over everything. Even making our children. It is AI. It is smarter and faster.
Aw'rite.
I am proceeding with the restoration.
Right now it is the recap.
What can I say....it is pretty tight in there.
I was able to restuff 3 backelites and two tubulars, plus some resistors.
I was in doubt about the 2x110pF block, but then I disconnected one cap and measured it; it was over 300pF, so, no, those inside were not micas.
The battery came out of its socket fairly easily. I wonder if I should try to fit LR44 there.
RE: Restoring Philco 37-604C - by morzh - 10-12-2024, 07:56 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
