Is this a model 44?
Yes indeed, it is a 44H:
http://www.philcoradio.com/gallery/1933d.htm#i
Yours looks very nice! Icon_thumbup
Is this a model 44? - by SamTanner - 07-29-2011, 01:15 AM
Re: Is this a model 44? - by Ron Ramirez - 07-29-2011, 06:22 AM
Re: Is this a model 44? - by TA Forbes - 08-02-2011, 04:16 PM
There are currently 10222 online users. [Complete List]
» 1 Member(s) | 10221 Guest(s)
