Another Update on model 87 restoration
Tube testers wer no better then. If it plays nice, it's good. Hum means weak caps. You did replace them didn;t you?
Re: Another Update on model 87 restoration - by codefox1 - 07-29-2011, 10:52 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6132 online users. [Complete List]
» 1 Member(s) | 6131 Guest(s)
