Philco 91 Speaker Replacement
Thank you. Someone mentioned earlier that 5 watts should do. I have ordered some other stuff and included a 5 watt 2K. I have a 10 watt. I will measure the current draw once I get this working. I replace the E caps prior to firing up any radio. The trans has been ordered. I did some cabinet work yesterday out in the garage while we had a nice day. Needs a fair amount of veneer work. That will test my skills.
Philco 91 Speaker Replacement - by dconant - 10-28-2024, 06:54 PM
RE: Philco 91 Speaker Replacement - by morzh - 10-28-2024, 07:22 PM
RE: Philco 91 Speaker Replacement - by dconant - 10-29-2024, 02:52 PM
RE: Philco 91 Speaker Replacement - by morzh - 10-29-2024, 04:28 PM
RE: Philco 91 Speaker Replacement - by Arran - 10-30-2024, 02:18 AM
RE: Philco 91 Speaker Replacement - by morzh - 10-30-2024, 09:07 AM
RE: Philco 91 Speaker Replacement - by dconant - 10-30-2024, 09:27 AM
RE: Philco 91 Speaker Replacement - by morzh - 10-30-2024, 09:41 AM
RE: Philco 91 Speaker Replacement - by dconant - 10-30-2024, 11:14 AM
RE: Philco 91 Speaker Replacement - by dconant - 10-31-2024, 08:45 AM
RE: Philco 91 Speaker Replacement - by RodB - 10-31-2024, 09:02 AM
RE: Philco 91 Speaker Replacement - by morzh - 10-31-2024, 09:15 AM
RE: Philco 91 Speaker Replacement - by dconant - 10-31-2024, 09:34 AM
RE: Philco 91 Speaker Replacement - by morzh - 10-31-2024, 09:44 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-01-2024, 11:54 AM
RE: Philco 91 Speaker Replacement - by morzh - 11-01-2024, 12:02 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-01-2024, 12:14 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-01-2024, 12:16 PM
RE: Philco 91 Speaker Replacement - by Arran - 11-01-2024, 04:07 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-01-2024, 04:26 PM
RE: Philco 91 Speaker Replacement - by RodB - 11-01-2024, 05:48 PM
RE: Philco 91 Speaker Replacement - by Arran - 11-01-2024, 08:11 PM
RE: Philco 91 Speaker Replacement - by RodB - 11-02-2024, 09:53 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-02-2024, 10:03 AM
RE: Philco 91 Speaker Replacement - by RodB - 11-02-2024, 11:16 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-02-2024, 11:23 AM
RE: Philco 91 Speaker Replacement - by RodB - 11-02-2024, 11:29 AM
RE: Philco 91 Speaker Replacement - by RodB - 11-02-2024, 11:36 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-02-2024, 11:56 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-03-2024, 01:04 PM
RE: Philco 91 Speaker Replacement - by RodB - 11-03-2024, 03:42 PM
RE: Philco 91 Speaker Replacement - by MrFixr55 - 11-03-2024, 10:43 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-04-2024, 08:15 AM
RE: Philco 91 Speaker Replacement - by morzh - 11-04-2024, 10:48 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-07-2024, 07:10 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-07-2024, 09:23 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-08-2024, 08:59 AM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 10:50 AM
RE: Philco 91 Speaker Replacement - by RodB - 11-08-2024, 10:52 AM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 11:15 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-08-2024, 01:14 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 01:48 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 01:54 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-08-2024, 02:32 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 03:32 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-08-2024, 04:49 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 08:53 PM
