Philco Model 77 Parts Layout sheet
Hi
I suggest you purchase the complete set of service information from Chuck at the Philco Repair Bench website. This will include everything you need, and the price is quite reasonable.
http://www.philcorepairbench.com/schematics.htm
Philco Model 77 Parts Layout sheet - by TonyM - 07-30-2011, 11:15 AM
Re: Philco Model 77 Parts Layout sheet - by Ron Ramirez - 07-30-2011, 02:34 PM
Re: Philco Model 77 Parts Layout sheet - by TonyM - 07-30-2011, 05:09 PM
Re: Philco Model 77 Parts Layout sheet - by TonyM - 07-31-2011, 06:37 PM
There are currently 10488 online users. [Complete List]
» 2 Member(s) | 10486 Guest(s)
