Philco 38-2 Automatic Tuning
You press the lever (crank) and you rotate the dial into the desired position.
Also, while pressed, the contact that it presses on will mute the radio.
Philco 38-2 Automatic Tuning - by dconant - 11-03-2024, 11:51 AM
RE: Philco 38-2 Automatic Tuning - by dconant - 11-03-2024, 01:11 PM
RE: Philco 38-2 Automatic Tuning - by morzh - 11-03-2024, 02:42 PM
RE: Philco 38-2 Automatic Tuning - by dconant - 11-04-2024, 08:22 AM
RE: Philco 38-2 Automatic Tuning - by radiorich - 11-04-2024, 09:14 AM
RE: Philco 38-2 Automatic Tuning - by morzh - 11-04-2024, 10:50 AM
RE: Philco 38-2 Automatic Tuning - by RodB - 11-04-2024, 11:00 AM
RE: Philco 38-2 Automatic Tuning - by morzh - 11-04-2024, 11:55 AM
RE: Philco 38-2 Automatic Tuning - by dconant - 11-04-2024, 01:17 PM
RE: Philco 38-2 Automatic Tuning - by morzh - 11-04-2024, 03:20 PM
RE: Philco 38-2 Automatic Tuning - by radiorich - 11-04-2024, 03:56 PM
RE: Philco 38-2 Automatic Tuning - by dconant - 11-04-2024, 04:13 PM
RE: Philco 38-2 Automatic Tuning - by rfeenstra - 11-05-2024, 01:20 AM
RE: Philco 38-2 Automatic Tuning - by poulsbobill - 11-05-2024, 12:16 PM
RE: Philco 38-2 Automatic Tuning - by dconant - 11-05-2024, 06:45 PM
RE: Philco 38-2 Automatic Tuning - by dconant - 11-11-2024, 12:39 PM
462ron - by 462ron - 11-12-2024, 08:58 AM
RE: Philco 38-2 Automatic Tuning - by dconant - 11-12-2024, 09:23 AM
462ron - by 462ron - 11-12-2024, 09:40 AM
RE: Philco 38-2 Automatic Tuning - by dconant - 11-12-2024, 09:51 AM
462ron - by 462ron - 11-12-2024, 10:34 AM
RE: Philco 38-2 Automatic Tuning - by dconant - 11-21-2024, 11:13 AM
462ron - by 462ron - 11-21-2024, 12:07 PM
RE: Philco 38-2 Automatic Tuning - by dconant - 11-21-2024, 12:27 PM
RE: Philco 38-2 Automatic Tuning - by morzh - 11-21-2024, 08:11 PM
