Philco 89B code 123 newbie
The HB coil is often shown in the schematic as an inductance symbol in series with the speaker after the secondary of the audio xfmr.
I suspect you might want the speaker with the humbucker, as the coil is used as the filter coil.
7100 Ohm is probably a mistake (I see it in the Code 123). It should be in hundreds of Ohms.
Anothe 89 sch shows 450 Ohms; this is more like it.
Philco 89B code 123 newbie - by Kurt P - 09-13-2024, 02:44 AM
RE: Philco 89B code 123 newbie - by radiorich - 09-13-2024, 08:12 AM
RE: Philco 89B code 123 newbie - by MrFixr55 - 09-13-2024, 09:36 AM
RE: Philco 89B code 123 newbie - by Kurt P - 09-23-2024, 04:43 PM
RE: Philco 89B code 123 newbie - by Radioroslyn - 09-23-2024, 09:46 PM
RE: Philco 89B code 123 newbie - by MrFixr55 - 09-24-2024, 06:06 PM
RE: Philco 89B code 123 newbie - by Radioroslyn - 09-24-2024, 09:25 PM
RE: Philco 89B code 123 newbie - by MrFixr55 - 09-24-2024, 10:07 PM
RE: Philco 89B code 123 newbie - by Radioroslyn - 09-25-2024, 10:28 AM
RE: Philco 89B code 123 newbie - by Kurt P - 09-27-2024, 05:35 PM
RE: Philco 89B code 123 newbie - by Radioroslyn - 09-27-2024, 08:50 PM
RE: Philco 89B code 123 newbie - by MrFixr55 - 09-28-2024, 09:03 AM
RE: Philco 89B code 123 newbie - by Kurt P - 10-15-2024, 03:07 PM
RE: Philco 89B code 123 newbie - by Kurt P - 10-18-2024, 01:30 PM
RE: Philco 89B code 123 newbie - by RodB - 10-18-2024, 03:29 PM
RE: Philco 89B code 123 newbie - by Radioroslyn - 10-18-2024, 05:15 PM
Kurt P - by Kurt P - 10-19-2024, 11:59 AM
RE: Philco 89B code 123 newbie - by Kurt P - 10-21-2024, 08:25 PM
RE: Philco 89B code 123 newbie - by Radioroslyn - 10-22-2024, 11:25 AM
RE: Philco 89B code 123 newbie - by Kurt P - 11-06-2024, 09:04 PM
RE: Philco 89B code 123 newbie - by morzh - 11-06-2024, 10:55 PM
RE: Philco 89B code 123 newbie - by MrFixr55 - 11-06-2024, 10:57 PM
RE: Philco 89B code 123 newbie - by Kurt P - 11-09-2024, 03:42 PM
RE: Philco 89B code 123 newbie - by MrFixr55 - 11-09-2024, 04:26 PM
