Philco 91 Speaker Replacement
#38
I see where the 10k ohms comes from in the tube data sheet. Where does the 95 turns ratio come from?
If I use 5.3 times 9000 I get 47, 700. There is nothing anywhere near that. Can you give me some examples if my voice coil measures 5.3 ohms?
What happens when the mismatch is not close?
Philco 91 Speaker Replacement - by dconant - 10-28-2024, 06:54 PM
RE: Philco 91 Speaker Replacement - by morzh - 10-28-2024, 07:22 PM
RE: Philco 91 Speaker Replacement - by dconant - 10-29-2024, 02:52 PM
RE: Philco 91 Speaker Replacement - by morzh - 10-29-2024, 04:28 PM
RE: Philco 91 Speaker Replacement - by Arran - 10-30-2024, 02:18 AM
RE: Philco 91 Speaker Replacement - by morzh - 10-30-2024, 09:07 AM
RE: Philco 91 Speaker Replacement - by dconant - 10-30-2024, 09:27 AM
RE: Philco 91 Speaker Replacement - by morzh - 10-30-2024, 09:41 AM
RE: Philco 91 Speaker Replacement - by dconant - 10-30-2024, 11:14 AM
RE: Philco 91 Speaker Replacement - by dconant - 10-31-2024, 08:45 AM
RE: Philco 91 Speaker Replacement - by RodB - 10-31-2024, 09:02 AM
RE: Philco 91 Speaker Replacement - by morzh - 10-31-2024, 09:15 AM
RE: Philco 91 Speaker Replacement - by dconant - 10-31-2024, 09:34 AM
RE: Philco 91 Speaker Replacement - by morzh - 10-31-2024, 09:44 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-01-2024, 11:54 AM
RE: Philco 91 Speaker Replacement - by morzh - 11-01-2024, 12:02 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-01-2024, 12:14 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-01-2024, 12:16 PM
RE: Philco 91 Speaker Replacement - by Arran - 11-01-2024, 04:07 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-01-2024, 04:26 PM
RE: Philco 91 Speaker Replacement - by RodB - 11-01-2024, 05:48 PM
RE: Philco 91 Speaker Replacement - by Arran - 11-01-2024, 08:11 PM
RE: Philco 91 Speaker Replacement - by RodB - 11-02-2024, 09:53 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-02-2024, 10:03 AM
RE: Philco 91 Speaker Replacement - by RodB - 11-02-2024, 11:16 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-02-2024, 11:23 AM
RE: Philco 91 Speaker Replacement - by RodB - 11-02-2024, 11:29 AM
RE: Philco 91 Speaker Replacement - by RodB - 11-02-2024, 11:36 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-02-2024, 11:56 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-03-2024, 01:04 PM
RE: Philco 91 Speaker Replacement - by RodB - 11-03-2024, 03:42 PM
RE: Philco 91 Speaker Replacement - by MrFixr55 - 11-03-2024, 10:43 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-04-2024, 08:15 AM
RE: Philco 91 Speaker Replacement - by morzh - 11-04-2024, 10:48 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-07-2024, 07:10 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-07-2024, 09:23 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-08-2024, 08:59 AM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 10:50 AM
RE: Philco 91 Speaker Replacement - by RodB - 11-08-2024, 10:52 AM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 11:15 AM
RE: Philco 91 Speaker Replacement - by dconant - 11-08-2024, 01:14 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 01:48 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 01:54 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-08-2024, 02:32 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 03:32 PM
RE: Philco 91 Speaker Replacement - by dconant - 11-08-2024, 04:49 PM
RE: Philco 91 Speaker Replacement - by morzh - 11-08-2024, 08:53 PM
