Philco 38-2 Low Volume
OK, so I'm seeing the B+ is about 25v low causing the overall performance to be reduced. How much I can't say. I looked at the screen voltage of the 6K6 output tubes and the schematic calls for 260v, which is the B+ right off the power supply. That B+ feeds resistor 14X. See where I'm going? Generally, a ten percent reduction is within tolerance but in this case it bears investigation because it's ten percent for each stage.
Philco 38-2 Low Volume - by dconant - 11-09-2024, 02:27 PM
RE: Philco 38-2 Low Volume - by morzh - 11-09-2024, 03:15 PM
RE: Philco 38-2 Low Volume - by MrFixr55 - 11-09-2024, 10:27 PM
RE: Philco 38-2 Low Volume - by RodB - 11-10-2024, 11:44 AM
RE: Philco 38-2 Low Volume - by dconant - 11-10-2024, 01:23 PM
RE: Philco 38-2 Low Volume - by dconant - 11-10-2024, 02:39 PM
RE: Philco 38-2 Low Volume - by morzh - 11-10-2024, 03:25 PM
RE: Philco 38-2 Low Volume - by MrFixr55 - 11-10-2024, 06:31 PM
RE: Philco 38-2 Low Volume - by RodB - 11-10-2024, 06:52 PM
RE: Philco 38-2 Low Volume - by morzh - 11-10-2024, 07:16 PM
RE: Philco 38-2 Low Volume - by dconant - 11-11-2024, 12:05 PM
RE: Philco 38-2 Low Volume - by RodB - 11-11-2024, 01:17 PM
RE: Philco 38-2 Low Volume - by dconant - 11-11-2024, 02:06 PM
RE: Philco 38-2 Low Volume - by dconant - 11-11-2024, 02:14 PM
RE: Philco 38-2 Low Volume - by RodB - 11-11-2024, 02:36 PM
RE: Philco 38-2 Low Volume - by dconant - 11-11-2024, 03:50 PM
RE: Philco 38-2 Low Volume - by dconant - 11-11-2024, 04:58 PM
RE: Philco 38-2 Low Volume - by RodB - 11-11-2024, 05:20 PM
RE: Philco 38-2 Low Volume - by RodB - 11-11-2024, 05:38 PM
RE: Philco 38-2 Low Volume - by dconant - 11-11-2024, 06:23 PM
RE: Philco 38-2 Low Volume - by RodB - 11-11-2024, 11:15 PM
RE: Philco 38-2 Low Volume - by dconant - 11-12-2024, 08:51 AM
RE: Philco 38-2 Low Volume - by RodB - 11-12-2024, 10:53 AM
RE: Philco 38-2 Low Volume - by morzh - 11-12-2024, 11:02 AM
RE: Philco 38-2 Low Volume - by dconant - 11-12-2024, 11:16 AM
RE: Philco 38-2 Low Volume - by morzh - 11-12-2024, 11:22 AM
RE: Philco 38-2 Low Volume - by RodB - 11-12-2024, 11:43 AM
RE: Philco 38-2 Low Volume - by morzh - 11-12-2024, 11:52 AM
RE: Philco 38-2 Low Volume - by dconant - 11-12-2024, 11:57 AM
RE: Philco 38-2 Low Volume - by morzh - 11-12-2024, 12:02 PM
RE: Philco 38-2 Low Volume - by dconant - 11-12-2024, 12:08 PM
RE: Philco 38-2 Low Volume - by MrFixr55 - 11-12-2024, 12:27 PM
RE: Philco 38-2 Low Volume - by morzh - 11-12-2024, 12:42 PM
RE: Philco 38-2 Low Volume - by dconant - 11-12-2024, 02:07 PM
RE: Philco 38-2 Low Volume - by morzh - 11-12-2024, 02:25 PM
RE: Philco 38-2 Low Volume - by dconant - 11-12-2024, 02:57 PM
RE: Philco 38-2 Low Volume - by MrFixr55 - 11-12-2024, 02:57 PM
RE: Philco 38-2 Low Volume - by MrFixr55 - 11-12-2024, 04:24 PM
RE: Philco 38-2 Low Volume - by dconant - 11-12-2024, 04:50 PM
RE: Philco 38-2 Low Volume - by MrFixr55 - 11-12-2024, 05:21 PM
RE: Philco 38-2 Low Volume - by dconant - 11-12-2024, 06:04 PM
RE: Philco 38-2 Low Volume - by dconant - 11-13-2024, 04:08 PM
RE: Philco 38-2 Low Volume - by morzh - 11-13-2024, 04:37 PM
RE: Philco 38-2 Low Volume - by dconant - 11-13-2024, 04:42 PM
RE: Philco 38-2 Low Volume - by morzh - 11-13-2024, 04:52 PM
RE: Philco 38-2 Low Volume - by dconant - 11-13-2024, 04:56 PM
RE: Philco 38-2 Low Volume - by morzh - 11-13-2024, 05:22 PM
RE: Philco 38-2 Low Volume - by dconant - 11-13-2024, 06:03 PM
RE: Philco 38-2 Low Volume - by MrFixr55 - 11-13-2024, 06:51 PM
RE: Philco 38-2 Low Volume - by MrFixr55 - 11-13-2024, 07:00 PM
RE: Philco 38-2 Low Volume - by dconant - 11-13-2024, 07:28 PM
RE: Philco 38-2 Low Volume - by morzh - 11-13-2024, 08:25 PM
RE: Philco 38-2 Low Volume - by dconant - 11-14-2024, 08:21 AM
RE: Philco 38-2 Low Volume - by dconant - 11-14-2024, 03:57 PM
RE: Philco 38-2 Low Volume - by morzh - 11-14-2024, 04:06 PM
RE: Philco 38-2 Low Volume - by dconant - 11-14-2024, 04:28 PM
RE: Philco 38-2 Low Volume - by dconant - 11-14-2024, 07:35 PM
RE: Philco 38-2 Low Volume - by morzh - 11-14-2024, 07:39 PM
RE: Philco 38-2 Low Volume - by dconant - 11-15-2024, 09:57 AM
RE: Philco 38-2 Low Volume - by morzh - 11-15-2024, 10:02 AM
RE: Philco 38-2 Low Volume - by RodB - 11-15-2024, 11:09 AM
RE: Philco 38-2 Low Volume - by dconant - 11-15-2024, 11:47 AM
RE: Philco 38-2 Low Volume - by RodB - 11-15-2024, 11:55 AM
RE: Philco 38-2 Low Volume - by dconant - 11-15-2024, 12:44 PM
RE: Philco 38-2 Low Volume - by dconant - 11-15-2024, 12:50 PM
RE: Philco 38-2 Low Volume - by morzh - 11-15-2024, 01:42 PM
RE: Philco 38-2 Low Volume - by RodB - 11-15-2024, 03:24 PM
RE: Philco 38-2 Low Volume - by morzh - 11-15-2024, 04:19 PM
RE: Philco 38-2 Low Volume - by dconant - 11-15-2024, 05:36 PM
RE: Philco 38-2 Low Volume - by MrFixr55 - 11-15-2024, 07:31 PM
RE: Philco 38-2 Low Volume - by RodB - 11-15-2024, 08:06 PM
RE: Philco 38-2 Low Volume - by dconant - 11-16-2024, 08:36 AM
RE: Philco 38-2 Low Volume - by radiorich - 11-16-2024, 12:12 PM
RE: Philco 38-2 Low Volume - by dconant - 11-17-2024, 10:55 AM
RE: Philco 38-2 Low Volume - by dconant - 11-21-2024, 11:03 AM
RE: Philco 38-2 Low Volume - by dconant - 12-04-2024, 08:41 AM
