Threads: 37
City: Marion
State, Province, Country: NY
No dim bulb just a isolation transformer. Input voltage was 113 now set to 118. Neither cap is grounded but connected to center tap of HV. Transformer does not get hot. I have seen most 120 degrees. Running with 5X4. I don't have another. With 118 volts in caps are at 325 and 295. Didn't notice any volume change. All DC voltages I report are from VTVM (RCA WV77E). Should I get another 5X4?
RE: Philco 38-2 Low Volume - by dconant - 11-12-2024, 11:16 AM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
