Threads: 37
City: Marion
State, Province, Country: NY
I connected my tape deck to the pot as stated with a .01 cap between. Volume is still low. Maybe I am expecting too much out of the radio. Full volume is way louder than I would want to listen too. It is not distorted at full volume. Other Philco radios I have worked on normal volume is about one third or less. The AVC and non peaking IF concerns me.
(This post was last modified: 11-12-2024, 02:57 PM by dconant.)
RE: Philco 38-2 Low Volume - by dconant - 11-12-2024, 02:57 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
