[split] Newbie questions RE: Philco 41-608
The cap to the left is 21B.  I have the negative tied to the ground with two terminal points.  (See first pic below).  I then have 21A + Red wire to the second terminal (Right) of the two terminal points and the - negative yellow going to the 4th terminal from the left R77. (Second pic)
21 + goes to the bottom terminal pin 2. (10 terminal points) - negative goes to the chassis ground which I put a terminal strip (See bottom 2 pics).
Let me know if you can see it clearly.
Thanks!
Todd
RE: [split] Newbie questions RE: Philco 41-608 - by tmurphy - 11-13-2024, 08:59 PM
RE: Newbie questions RE: Philco 41-608 - by morzh - 11-12-2024, 10:46 AM
