Philco Model 77 Parts Layout sheet
Its a lowboy cabinet.
Picture in its original condition attached.
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Philco Model 77 Parts Layout sheet - by TonyM - 07-30-2011, 11:15 AM
Re: Philco Model 77 Parts Layout sheet - by TonyM - 07-30-2011, 05:09 PM
Re: Philco Model 77 Parts Layout sheet - by TonyM - 07-31-2011, 06:37 PM
There are currently 9427 online users. [Complete List]
» 1 Member(s) | 9426 Guest(s)
