model 41-280 no stations or sound
Measure the voltages on each 41 tube. Pins 2,3,and 4 to chassis report back
model 41-280 no stations or sound - by williec - 07-31-2011, 01:07 PM
Re: model 41-280 no stations or sound - by 7estatdef - 07-31-2011, 08:32 PM
There are currently 10076 online users. [Complete List]
» 2 Member(s) | 10074 Guest(s)
