model 19
Used to have a tube tester but gave it away last time we moved.
Counted the turns and wound them the same way as they were.
model 19 - by vinzer - 07-30-2011, 10:40 PM
Re: model 19 - by rghines1 - 07-31-2011, 09:52 AM
Re: model 19 - by Ron Ramirez - 07-31-2011, 11:20 AM
Re: model 19 - by vinzer - 07-31-2011, 06:06 PM
Re: model 19 - by 7estatdef - 07-31-2011, 06:16 PM
Re: model 19 - by exray - 07-31-2011, 07:30 PM
Re: model 19 - by vinzer - 07-31-2011, 10:45 PM
Re: model 19 - by exray - 08-01-2011, 06:57 AM
Re: model 19 - by vinzer - 08-02-2011, 10:14 PM
Re: model 19 - by AI2V - 08-06-2011, 12:03 PM
Re: model 19 - by vinzer - 08-06-2011, 08:29 PM
Re: model 19 - by vinzer - 08-06-2011, 09:48 PM
The speaker table error?
Philco 70 antenna lead
