Welcome Eric,
I agree with Bob and far as the two main electrolytic filter capacitors did you change them yourself or were they changed in the past ?
Philco 46-420 Code 121 Reception issues - by Eric - 10-29-2024, 04:57 PM
RE: Philco 46-420 Code 121 Reception issues - by radiorich - 11-24-2024, 11:43 PM
