model 41-280 no stations or sound
I haven't messed with the adjustment screws and there is one wire that's broken that I need to fix. I still can't understand why this other 41-250 works so well. Barely turn on the vol. and it comes in really good. Even being a novice at this I don't think the chassis has ever been out of the cabinet. The power cord is almost like new but went ahead and changed it.
model 41-280 no stations or sound - by williec - 07-31-2011, 01:07 PM
Re: model 41-280 no stations or sound - by williec - 08-01-2011, 03:49 PM
There are currently 10143 online users. [Complete List]
» 2 Member(s) | 10141 Guest(s)
