Philco 60 Squealing
Rod, I had checked out your suggestions but did not help. I did solder the ground rivets to the chassis as Chas suggested.
Good news! The squealing is gone, now that I have corrected my wiring mistake. I had the oscillator grid wire connected to the top connection of the the antenna coil and the pin 5 of the antenna coil connected to the top connection. So basically backwards I guess. I didn't think I was going to solve this one.
My radio has what is called a wave trap but the alignment instructions don't say what to do with it so I just peaked it for the best signal at 600. Hopefully that is correct.
Philco 60 Squealing - by dconant - 11-25-2024, 10:55 AM
RE: Philco 60 Squealing - by Chas - 11-25-2024, 01:24 PM
RE: Philco 60 Squealing - by dconant - 11-26-2024, 02:13 PM
RE: Philco 60 Squealing - by morzh - 11-26-2024, 05:14 PM
RE: Philco 60 Squealing - by dconant - 11-26-2024, 06:25 PM
RE: Philco 60 Squealing - by Chas - 11-26-2024, 07:23 PM
RE: Philco 60 Squealing - by fenbach - 11-26-2024, 08:48 PM
RE: Philco 60 Squealing - by dconant - 11-27-2024, 09:07 AM
RE: Philco 60 Squealing - by RodB - 11-27-2024, 01:35 PM
RE: Philco 60 Squealing - by dconant - 11-27-2024, 04:52 PM
RE: Philco 60 Squealing - by morzh - 11-27-2024, 05:19 PM
RE: Philco 60 Squealing - by Chas - 11-27-2024, 08:05 PM
RE: Philco 60 Squealing - by RodB - 11-27-2024, 09:30 PM
RE: Philco 60 Squealing - by dconant - 11-28-2024, 09:21 AM
RE: Philco 60 Squealing - by RodB - 11-28-2024, 10:07 AM
RE: Philco 60 Squealing - by dconant - 12-02-2024, 09:39 AM
RE: Philco 60 Squealing - by RodB - 12-02-2024, 10:54 AM
RE: Philco 60 Squealing - by morzh - 12-02-2024, 12:01 PM
RE: Philco 60 Squealing - by dconant - 12-03-2024, 08:54 AM
