Philco 87
Jimony, don't dispair, I had a lot of trouble with my first one, as a matter of fact it is still not up and running. The transformer will have to be replaced if possible. If a replacement can't be found you may be able to get it re-wound. The AF coil I am not familiar with but will take a look at the schematic and see if I can come up with an idea. Do you mean the first IF transformer? These alternative may get expensive so you will have to make a discision as to how to play it.
Philco 87 - by Jimony - 06-28-2006, 05:59 PM
Philco 87 - by planigan - 07-05-2006, 12:36 AM
Philco 87 - by Jimony - 07-05-2006, 04:18 PM
Philco 87 - by planigan - 07-05-2006, 05:42 PM
[No subject] - by Carl Travis - 07-06-2006, 09:05 AM
Philco 91 Tuning Condenser
