41-608 distortion issue
You’re welcome! I’m following with a curiosity. I have a 49-906 which had a tube go out on the FM RF circuit, and it caused a similar issue with audio reproduction. Just the same, I was able to narrow it down to just the one function, and found it to be the tube. That’s really the only reason I’m feeling confident in my assumption.
Joseph
Philco 46-480
Philco 49-906
41-608 distortion issue - by philco4me - 12-11-2024, 07:05 PM
RE: 41-608 distortion issue - by jrblasde - 12-11-2024, 08:26 PM
RE: 41-608 distortion issue - by philco4me - 12-11-2024, 08:42 PM
RE: 41-608 distortion issue - by jrblasde - 12-11-2024, 08:55 PM
RE: 41-608 distortion issue - by philco4me - 12-11-2024, 09:09 PM
RE: 41-608 distortion issue - by jrblasde - 12-11-2024, 09:12 PM
philco4me - by philco4me - 12-11-2024, 09:17 PM
RE: 41-608 distortion issue - by jrblasde - 12-11-2024, 09:20 PM
RE: 41-608 distortion issue - by philco4me - 12-11-2024, 09:45 PM
RE: 41-608 distortion issue - by jrblasde - 12-11-2024, 10:39 PM
RE: 41-608 distortion issue - by jrblasde - 12-12-2024, 10:04 PM
RE: 41-608 distortion issue - by philco4me - 12-14-2024, 10:46 AM
RE: 41-608 distortion issue - by jrblasde - 12-14-2024, 11:01 AM
RE: 41-608 distortion issue - by MrFixr55 - 12-14-2024, 12:20 PM
RE: 41-608 distortion issue - by jrblasde - 12-14-2024, 01:14 PM
RE: 41-608 distortion issue - by philco4me - 12-29-2024, 01:24 PM
RE: 41-608 distortion issue - by jrblasde - 12-29-2024, 02:09 PM
