Another Update on model 87 restoration
>although it certainly won't hurt anything to add them.<
If you like getting shocked if you are grounded and you touch the chassis. But it only hurts a little cause the current is low.
I don't know if it will effect your hum problem. I would suspect that grounding the chassis to a good ground would do the same thing.
Re: Another Update on model 87 restoration - by 7estatdef - 08-02-2011, 01:57 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6312 online users. [Complete List]
» 2 Member(s) | 6310 Guest(s)
