Philco 87
Jimony, just so I know what we are talking about, the xfmer is part #25 2nd AF xfmer right? From the schematic that looks like an iron core xfmer, but since you are saying it "melted down", I'm assuming its tubular cardboard with coils wire wrapped around it, is that so? Pat
Philco 87 - by Jimony - 06-28-2006, 05:59 PM
Philco 87 - by planigan - 07-05-2006, 12:36 AM
Philco 87 - by Jimony - 07-05-2006, 04:18 PM
Philco 87 - by planigan - 07-05-2006, 05:42 PM
[No subject] - by Carl Travis - 07-06-2006, 09:05 AM
There are currently 9982 online users. [Complete List]
» 1 Member(s) | 9981 Guest(s)
