(Safely) Removing Rust from Chassis
Wow, really? I never thought vinegar could be so potent. Was the rust pretty severe to start with?
Joseph
Philco 46-480
Philco 49-906
(Safely) Removing Rust from Chassis - by jrblasde - 12-27-2024, 09:57 AM
RE: (Safely) Removing Rust from Chassis - by RodB - 12-28-2024, 12:17 AM
RE: (Safely) Removing Rust from Chassis - by jrblasde - 12-28-2024, 11:08 AM
