Another Update on model 87 restoration
7estatdef Wrote:I don't know if it will effect your hum problem.
The OP claims, "The hum is more like a buzz I guess." The addition of a single line to ground filter - could eliminate this "buzz". No harm trying, it's only a 10 min. job.
-Greg
Re: Another Update on model 87 restoration - by gvel - 08-03-2011, 06:39 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6238 online users. [Complete List]
» 1 Member(s) | 6237 Guest(s)
