Philco 89 BC Resistor
Need to know how to rebuild or replace BC Resistor in model 89 code 123. I am using a Rider schematic. Part #32 32 ohms and part #33 235 ohms. I have retired and trying to learn vintage radio repair. Thanks for your help.
Philco 89 BC Resistor - by dbrown - 08-03-2011, 11:05 AM
Re: Philco 89 BC Resistor - by 7estatdef - 08-03-2011, 06:19 PM
Re: Philco 89 BC Resistor - by Steve Davis - 08-03-2011, 08:32 PM
Re: Philco 89 BC Resistor - by dbrown - 08-03-2011, 09:44 PM
Re: Philco 89 BC Resistor - by codefox1 - 08-03-2011, 09:56 PM
Re: Philco 89 BC Resistor - by dbrown - 08-03-2011, 10:21 PM
Re: Philco 89 BC Resistor - by dbrown - 08-30-2011, 08:39 PM
The speaker table error?
Philco 70 antenna lead
