Philco 643 color scheme and modification
The grain on the face of the 1936 cabinets can be a booger to get smooth, I feel your pain. The 630 that I have been working on since last winter is still not acceptable. I am almost to the point that I am considering just installing it in a 623 console cabinet. But that would involve orphaning a nice 623 chassis. Decisions, decisions........
BUT that is some nice grain patterns on your 643. Your hard work will pay off with an extra nice looking set.
Re: Philco 643 color scheme and modification - by TA Forbes - 08-03-2011, 08:50 PM
