01-11-2025, 10:34 PM
BTA, the trick to add a teardrop to a pad that is not directly on the way of your 45 degree trace (your square pads) is to break the trace in the middle and zig-zag to another 45 degree trace that noaw has the target pad on its way.
(Or, in case you do not mind using non-45 degree angles, just to go to "any angle" routing mode and draw a direct trace between the two pads).
